Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Suburban
Brakes
ABS
Module
Replace/Remove
Dealer says I need new abs module
2002 CHEVROLET SUBURBAN
LLISAD
MEMBER
1 POST
dealer says I need new abs module. is that the same as an abs modulator valve? should any other parts be replaced at time of repair.
Dec 15, 2009 at 9:25 AM
DANNY L
Experienced Mechanic
Hello, I'm Danny
Here is a You Tube video made for our site for you to view.
https://youtu.be/lUotkKXG9dY
I've attached picture steps below as well show abs module replacement for your Suburban. You might have to have the abs module re-calibrated with a professional scan to for correct tire size. Hope this helps and thanks for using 2CarPros.
Images (Click to enlarge)
Mar 15, 2021 at 4:13 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
