2002 Chevy Suburban ABS and Break Warning Light
97,600 MILES • V8 • 2WD • AUTOMATIC
QUINTFR
I just recently change my break pads front and back because they were running low, also the ABS and Break warning light was coming on. After changing all the pads the warning light keeps coming on, is there a way to reset the warning light?, or there is another problem that I need to fix to make the warning light turn off?
Jul 6, 2010 at 2:29 PM
SATURNTECH9
  • 30,869 POSTS
You need to have your abs computer scanned for code's you have a fault in your abs system that's why the abs light is on.
Jul 6, 2010 at 6:07 PM
