2002 Chevy Suburban ABS
90,000 MILES • V8 • 4WD • AUTOMATIC
XLN868
Hello!
My ABS system will go on when i come to low speed and i loose brake,the problem get more frequent when turning the steering wheel to max at right or left at low speed and hit the brake(The ABS motor is running and I loose brakes)Sensors at left and right front are new.
Oct 1, 2009 at 6:45 PM
SERVICE WRITER
  • 9,123 POSTS
The abs system needs to be monitored with a hand held computer that can read the input from the sensors. The sensors may be fine, but the harness may be at fault. Regardless of the source this is where diagnosing this begins. There will be codes stored in the computer possibly to narrow this down, but getting to see what is being lost is needed. Once the offending circuit is found, testing can then be done on the sensors, harness etc.
Mar 15, 2021 at 4:22 AM
XLN868
Thank you for your answer!
I guess I have to vist a workshop who has that
handcomputer?
B.g.
Ronny Denlov
SERVICE WRITER
  • 9,123 POSTS
Testing is the best way to go about it. You can check the harnesses and do continuity checks as well as the connectors, but it would be far more effecient to check with the scanner to start narrowing down the problem.
