2001 Fuel Pump
150,000 MILES • V8 • 2WD • AUTOMATIC
WANGLERFAMILY
I was sitting in my car with it on and all of a sudden the engine light came on and said check oil pressure and the car turned off and will not restart. The fuel pump was not getting any power so i replaced fuel pump and relay switch and still no power to the fuel pump....someone told me that the fuel pump reset button might need to be pushed but had no idea where it was located....where is this stupid thing cant find it anywhere....what else could be the problem
Aug 17, 2008 at 4:44 PM
JETSA
  • 117 POSTS
There is no fuel pump reset button on Chevy's. If the oil light came on then the truck died, possibly the engine oil pressure switch is defective OR perhaps the engine oil pressure is low. The switch cuts off power to the fuel pump killing the engine to save it when low oil pressure conditions are present.
Aug 18, 2008 at 4:39 PM
