2001 Chevy Suburban water in floorboard
2001 CHEVROLET SUBURBAN
77,000 MILES • 6 CYL • 2WD • AUTOMATIC
JNETCOOK
When it rains the floor in the back seat is wet. It has become worse and now the driver's floor is soaking wet. There are no visible tears/leaks in the rubber molding around the doors, in the running boards etc. There is no indication, water marks/tracks of where the water is coming from.
Any suggestions?
Thanks for the help!
Feb 4, 2010 at 5:19 AM
SERVICE WRITER
  • 9,123 POSTS
Water leaks are a little bit of a specialty. WE have a guy come in to do them and he also services all the dealers in the area.
What he does is remove all of the insulation/sound deadening material from under the carpet, pulls off interior trim to get a better look. ( that will need to be replaced as it will cause mold,odor and rot problems.) Then sprays down the truck in certain areas at a time and observes. Sometimes clues are seen once the panels are off
Keep in mind you want to simulate rain, not hurricane gale force winds by using a sprayer.
I would be most suspicious of areas around fixed windows first.
Feb 4, 2010 at 8:29 PM
GETTRACTORS
It is coming from your left rear fender well. GM Bulliten 03-08-57-001A. Water travels all the way up the rocker sill plate to the front carpet as well. Can patch with sealant.
Jan 23, 2015 at 12:14 AM
