1998 Chevy Suburban windshield wipers
JIMBO 1
  • 1998 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 126,000 MILES
Last night while it was raining the wipers worked fine. Then without warning they stopped and now I hear a humming noise when I attempt to turn them on. Any suggestions would be appreciated.
Saturday, May 15th, 2010 AT 10:09 AM
HMAC300
  • 48,601 POSTS
Youi'll have to check if the wiper switch is grounding the wiper motor so it will work. The switch completes the circuit to make a wiper work. There is also a circuit board in the wiper that operates the delay and that can go bad. It's about $50 for that. You may have a ground in the wiper motor that has broken loose so you need to check that.
Tuesday, May 18th, 2010 AT 8:49 PM
