2001 Chevy Suburban uneven tire wear
50,000 MILES • V8 • 2WD • AUTOMATIC
MARYPRINZ
left front wreck 2003,auto + tires fine until 9/09,left frt tire uneven wear tometal new tire drove 10 miles tire hasstarted slightscallop on outter edge everything else appears normal. what causes this condition. i hate to drive the car the wear appears rapid alignment or front end work.thanks
Sep 22, 2009 at 7:07 AM
JEEPFAN
  • 135 POSTS
certain tire wear that is referred to as cupping can be caused by an out of balance tire or wheel or a bent rim a loose or worn tie rod or idler arm or worn front suspension parts. i would start by checking these things first since the vehicle was involved in a wreck. if all these things are in good condition have a front end alignment
Sep 23, 2009 at 6:45 AM
