2001 Chevy Suburban seats
95,000 MILES • V8 • 4WD • AUTOMATIC
JKGORDON1
The seat controls and heated seat function works intermittently; mostly does not work. There seems to be a connection with which driver key is used to start the engine; however, it is not consistent. I suspect a poor electrical connection. Where do I look?
Dec 31, 2007 at 9:15 AM
MIKE H R
  • 3,094 POSTS
With it working at times i WOULD check the connections under the seat itself. With the movement of the seat the connection could have come loose. make sure the connections are tight.
Jan 8, 2008 at 1:01 AM
