2001 Chevy Suburban removing rear rotors
2001 CHEVROLET SUBURBAN
139,000 MILES • 6 CYL • 4WD • AUTOMATIC
MSCANN
im having trouble removing the rear roors on my suburban i have a feeling its got something to do with the emergency barke. would appreciate some instructiion
Aug 7, 2010 at 5:20 AM
2CARPRO JACK
  • 11,533 POSTS
If it is the E-brake the rotor will move around, but not come off.If the rotor is stuck on the axle it wont wiggle at all.Try turning the axle while pulling out on the rotor if it is the brake holding it.If it wont budge off the axle, try tapping the face of the rotor between the wheel studs to jar it loose, or if that doesn twork you can tap it from behind with a hammer. If it still wont come off you may have to get a little rough with it to pop the brake shoe off its clip and allow the rotor to come off.
Mar 15, 2021 at 4:51 AM
