5.3L Engine w/ 98,400 miles - How do I adjust my emergency brakes? My emergency brakes have no effect. All cables are good. The in-line cable adjustment (a single to double cable 'T' section) is adjusted to its maximum point. The cable is slightly pulling on on the rear wheel levers when the emergency pedal is fully depressed. There appears to be sufficient pad remaining (rear disc brakes). Must I change the pads? My CD service manual does not cover this area very well.
Jun 26, 2007 at 5:15 AM
