2001 Chevy Suburban Fuel pump trouble
HUNTERXX1
  • 2001 CHEVROLET SUBURBAN
  • V8
  • 130,000 MILES
I have changed the fuel pump 4 times and it needs changing again. The first times I concluded it was due to a dirty tank since I found out the third time the mechanic was not cleaning the tank when he replaced the pump. The fourth time it was changed I saw it my self be cleaned and they also found the power line to be faulty like three inches before the plug to the pump. The mechanic said that could have been the cause or the very extremely dirty tank. I cant decide which one caused those pumps to burn out. But this time I had the wires looked at and pump changed and it still burned out. Usually I would hear the pump make a noise like before but this time nothing. I was also wondering if I change the pump for it with a 5.7litre instead of a 5.3litre would it affect in any way fuel economy or performance in a 'bad' way?(The last question was just extra knowledge for me)
Wednesday, April 29th, 2009 AT 11:19 AM
JDL
  • 16,098 POSTS
What Fuel pumps are you using, did they fail under warranty? Usually the manufacturer has a web page and email address, sometimes, if I have a question about one of their parts or I run out of ideas, why their part keeps failing, I email the manufacturer directly. They always reply, sometimes it's the next day or so, depending on how busy they are. They could probably also give you applicable information about switching to a different pump.
Wednesday, April 29th, 2009 AT 12:04 PM
