2001 Chevy Suburban clipped harness wires from factory radi
114,000 MILES • V8 • 4WD • AUTOMATIC
PITBULL 01
now my speed odometer and gas gauges and ac and heat is not working
Jul 14, 2010 at 10:20 AM
HMAC300
  • 48,601 POSTS
all you need to do is fix the wires you clipped and thing should be back to normal. Just make sure to do it correctly using steel connectors solderin and using shrink tubing to cover them. Do not use the crimp type connectors as you will have trouble rather quickly.......
Jul 14, 2010 at 11:39 AM
