2001 Chevy Suburban Brakes not working safely
2001 CHEVROLET SUBURBAN
193,000 MILES • V8 • 4WD • AUTOMATIC
ABEL44
When i step on my brakes it pulsates on the pedal and wont stop unless i press the brakes real hard. Now this is not the pulsating like when the rotor is warped, its a total different feeling. It does this when i slow down to about 8 mph. I changed the front pads last night but that didnt changed anything, so im going to change the rear pads because its low also. Also should i bleed the brake systems. If that doesn't work can you give any suggestions. Somebody told me it might be the abs systems but i dont no to much about that. Can you me some specifics please, Thank You.
Dec 27, 2009 at 7:46 AM
BILLYMAC
  • 2,204 POSTS
hi
try and pull the fuse for the abs .and drive if does not do this with fuse out then the prob is in the abs.
let me know and i will tell you how to diag an abs prob
Dec 29, 2009 at 1:11 PM
