I recently was driving my vehicle when I had a slight hesitation. I quickly paid attention and it did it again. As I got closer to my home it did it more. I floored it but it didnt rev up or go faster. When I got home I let it set for 10 min or so then took it out for a spin on the highway to see if I had bad gas or water in it. I had no problem. I stopped and put in some heat and started it up. It ran for a sec and then died. I got it home by towing. I quickly went the cheapest way and replaced the fuel filter, but still same issue. I started it up and it ran rough then slowly died. I figure it is the fuel pump. But another thing to add. My wife who drives this more than me has been seeing the dash lights flicker bad at idle and sometimes driving. Also the stock stereo has reset the clock several times. I am not sure that this could be all tied to the ignition module.
Oct 25, 2008 at 6:27 PM
