2000 Chevy Suburban Service 4WD
162,251 MILES • V8 • 4WD • AUTOMATIC
CHISSYN8
My message center is displaying Service 4WD. Can you tell me what is involved with this ? and if it will harm the vehicle if I continue to drive? Approximate cost and if this adealer service issue or not. Thank you.
Sep 23, 2008 at 1:04 PM
THIS IS MIKE
  • 686 POSTS
You should have the computer scanned for trouble codes. The message center is telling you there is a problem with the 4WD system. Your Suburban is probably only using 2WD currently and may be having difficulty with the switch($70) or the actuator($150) that engages the 4WD.
Sep 24, 2008 at 7:38 AM
