2000 Chevy Suburban Fuel Gauge
95,500 MILES • V8 • 2WD • AUTOMATIC
HEATHERMCCRACKIN
I filled up my suburban this past friday, on monday as i was driving down the road the low fuel light came on and started beeping and within seconds went right back up to full. now i have put 150 miles on the tank of gas and it is still reading full. all other gauges are working correctly.
Dec 10, 2009 at 3:52 AM
BIGZ
  • 21 POSTS
It sounds like your sending unit in the gas tank is going bad.Mind had the same symptom's and i replace it and works OK now,try replacing your fuel pump and not one from the junkyard.Pep boys Autoparts store have them from around $200 to $250 dollars and that is a carter fuel pump.Hope this helps you.
Dec 10, 2009 at 4:39 AM
