2000 Chevy Suburban Exhaust Manifold
147,000 MILES • V8 • 4WD • AUTOMATIC
OHIOBOB
Getting ready to replace the right exhaust manifold.
Just wondered if you know of tricks to get to exhaust bolts off without breaking them off in the head. I'm going to soak to heck out of them with WD-40 and the like.
Also need the torq.spec. of the bolts.
Thnks in advance
Feb 4, 2009 at 12:04 PM
2CARPRO JACK
  • 11,533 POSTS
Soaking them is your best bet, loosen by hand, no impact guns.The torque spec is 11ft lbs first pass then 18ft lbs second pass
Feb 4, 2009 at 1:07 PM
MMPRINCE4000
  • 8,548 POSTS
Use PB blaster to loosen bolts. WD-40 is a Water Displacer (WD) and while it is good for many things, PB Blaster is far superior in removing rusted/difficult bolts.
Coat new bolts with a dab of antisieze and torque as Jack said. Use a thread chaser to clean up threads in head.
Feb 4, 2009 at 2:34 PM
