2000 Chevy Suburban A/C Idle
OSCAR.SARAVIA
  • 2000 CHEVROLET SUBURBAN
  • V8
  • 115,000 MILES
The engine in my SUB is working fine, but when I turn the A/C on the engine wont stay running,
I Have to accelerate it a little bit to keep it running,
when turning in the road the engine died by it self.
Is any sensor or bypass that I have to replace or what can be the problem?
Sunday, August 31st, 2008 AT 10:17 AM
2CARPRO JACK
  • 11,533 POSTS
Try cleaning the Idle Air Control Motor. Also clean out around the butterfly in the throttle bore with carb cleaner and a rag. This should help stabilize the idle. If that doesnt work, you may have an IAC motor that is slow and needs to be replaced
Monday, September 1st, 2008 AT 7:35 AM
