1999 K1500 Suburban Steering Pull
MATES
1999 K1500 Suburban with 134,000 miles, 5.7l engine. My Suburban pulls to the right and has a steering wheel shake (mild) between 40 & 60 MPH. I've balanced and rotated the tires several time. The brakes have been inspected and check out green. Just completed a front end alignment and front end is in factory specs. After all of this, still have the right hand pull and wheel shake. What could be the cause of this? I was told that the Steering Wheel Position Sensor could be at fault. Please advise.
Nov 16, 2007 at 7:48 AM
PEAR69
  • 1,482 POSTS
This sounds like a sticking brake caliper. When your brakes get hot sometimes the piston inside the caliper sticks. This is hard to diagnosis by just visually inspecting the brakes. With 134,000 miles it's a good idea to change the brake calipers anyway. Spend a little extra and put new ones on it's worth it believe me. I would put new rotors on it also if there is any shaking, but it may not be necessary. Normaly when a steering wheel sensor goes bad the steering will jump all around and it seems like the steering has a mind of it's own. Usually there will be a trouble light associated with sensor problem also. Let me know how you make out.
This site runs on small or large donations, please try to make one Thanks
Nov 21, 2007 at 3:49 AM
