The burb won't start consistently. We replaced the fuel filter, the fuel pump works, and we changed the fuel pump regulator. It will start if we prime it with gas. So , we do that, let it run for a while, shut it off and if we turn the ignition back on within an hour it will start sitting any longer than that it will not. Also have an OBD code of 300 which is random misfire detected.Would that contribute to starting problems?
Out of ideas on the fuel system. Any thoughts?
Thanks,
Heather
Thanks,
Heather
Nov 2, 2008 at 1:31 AM
