1999 Chevy Suburban turbocharger
1999 CHEVROLET SUBURBAN
ROSSPARKINSON
  • 7 POSTS
Engine Mechanical problem
1999 Chevy Suburban 6.5L Four Wheel Drive Automatic 185000 miles
turbocharger not working. Accessory vacuum pump making "louder" knocking noise, and new knocking noise appears to have developed just behind turbocharger. Any common suggestions? Vacuum pump always starts to knock and must be replaced. Might be unrelated to Turbo?
Jun 6, 2009 at 2:05 AM
MMPRINCE4000
  • 8,548 POSTS
If you are not getting any boost, the wastegate must be completely open. This is probably mechanical (wastegate stuck open due to soot).
As long as turbo in not blowing blue smoke, the turbo itself should be OK.
Jun 6, 2009 at 2:09 AM
ROSSPARKINSON
  • 7 POSTS
Thanks I'll try it.
Jun 6, 2009 at 4:45 AM
MMPRINCE4000
  • 8,548 POSTS
Wastegates on these are electronicaly controlled, but mechanical moving wastgate to adjust boost.
Jun 7, 2009 at 12:42 AM
