Engine Mechanical problem
1999 Chevy Suburban V8 Four Wheel Drive Automatic
My Suburban is having intermittent issues starting. It will sometimes turn over, roar to life, and then die. Other times is starts fine, but then rough idles. It never has this problem more then once a day.
When I put a scan tool on it, it came up with "P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input." Is this a case of replacing the MAP sensor, and if so how do I do that? My car maintenance/repair experience is limited.
Nov 2, 2009 at 2:59 AM
