1999 Chevy Suburban trans problems
1999 CHEVROLET SUBURBAN
136,000 MILES • V8 • 4WD • AUTOMATIC
JJFADELY
no 1st and 4th gear runs fine cold when warm the problem starts throwing a 3-2 shift solenoid code (P0785) replaced along with all other solenoids and trans wiring harness still smae problem and code
Sep 24, 2010 at 10:12 PM
HMAC300
  • 48,601 POSTS
have a trans pro look at this, it may be the trans has burnt out that clutch pak or you could have someting cracked inside the trans or a blown out gasket between the valve body and plate.
Sep 30, 2010 at 2:04 AM
