1999 Chevy Suburban starting
SE3160
  • 1999 CHEVROLET SUBURBAN
Engine Mechanical problem
1999 Chevy Suburban V8 Four Wheel Drive Automatic 130k miles
I have a 99 V8 Vortec, 130 K miles. I just recently had the fuel pump replaced. I am having a problem getting the engine started/turning over. In the morning the engine starts up immediately. But, throughout the day, I have to keep the ignition turned and the engine takes quite a while to turnover. Is due to the spark plugs needing to be replaced, or could the fuel pump have something to do with it?
Monday, October 27th, 2008 AT 6:20 PM
MASTERTECHTIM
  • 4,749 POSTS
Could still be related to the fuel pump. These pumps are horrible, bring it back to the mechanic and he can do a amp draw test on the pump to make sure its pulling atleast 10 amps, this will indicate a good fuel pump. There are many problems with the wiring connector going to the pumps, heating up and corroding. Hope this helps
Monday, October 27th, 2008 AT 6:30 PM
