1999 Chevy Suburban Starter and Ignition
1999 CHEVROLET SUBURBAN
93,000 MILES • V8 • 4WD • AUTOMATIC
FAUVERT
I have a 99 suburban. The starter went bad, just clicked when turned key. I replaced the starter with a new one. When I hooked up the ground wire on the battery, the starter started turning the engine over. the key was not in the ignition. I took the starter back and had it tested because, i thought it must have a faulty solenoid, but it tested ok. I put the starter back on and hooked up the ground wire to the battery. Again the starter immediately started turning over the engine. I then turned the key on and hooked up the battery to see if it woudl start the truck and it turned the engine over, tried to start but would not. Almost like it was not getting enough fuel. I have looked for loose wires etc and checked fuses. could the problem be the ignition?
Oct 22, 2009 at 1:21 PM
Hi fauvert and TY for the donation
The starter relay could be sticking closed causing it to crank the egnine over w/o the key
Do this find the starter relay at left rear of engine compartment underhood fuse/relay center-remove it and see what happens if it stops cranking replace the relay.
If its cranking over and will not start do below to determine if its fuel or spark problem.
All that disconnection of the battery on and off probably caused the computer to lose its memory
Oct 22, 2009 at 1:38 PM
FAUVERT
I pulled the starter relay in the fuse box under the hood on the drivers side and the engine still cranks over without the key.
Oct 22, 2009 at 2:31 PM
Do this disconnect the battery and then remove the purple wire on the starter solenoid isolate it from ground. Now hook battery back up and check for power on the purple wire -Do you have power?
Oct 22, 2009 at 5:44 PM
FAUVERT
I unhooked the purple wire, hooked the battery back up and the starter kicked on immediately. While the starter was running i checked the purple wire. It had no power. I assume that this is a solenoid problem based on this result. I called autoparts and they are going to exchange it in the morning. Is there anything else it could be.
Oct 23, 2009 at 11:56 AM
The purple wire has power bcuz the solenoid is grounded passing the battery power to it-get the starter squared away
Oct 23, 2009 at 1:46 PM
FAUVERT
I exchanged the starter and it fixed the problem. The solenoid was stuck. The starter still tested as working properly at the autoparts so I had to argue a little bit.
thanks
Oct 24, 2009 at 3:21 AM
