1999 Chevy Suburban shifter column
125,000 MILES • V8 • 4WD • AUTOMATIC
NETTECH
I have a 1999 chevy suburban k1500 and recently found it very hard to shift from park to any other position, I removed the bottom piece of the dash board and saw where the shift connects to the stearing columum was cracked, trying to find the name of that piece
Jan 1, 2009 at 1:41 PM
ZEUSWS6
  • 5 POSTS
I'm in the same boat after some drift busting the linkage got frozen. I've got it thawed out now but I believe there is a part or two in the column that is broken. Have you gotten yours back together? If so, what did you have to replace?
Thanks,
Chris
[quote:07f5ef51de="nettech"]Transmission problem
1999 Chevy Suburban V8 Four Wheel Drive Automatic 125000 miles
I have a 1999 chevy suburban k1500 and recently found it very hard to shift from park to any other position, I removed the bottom piece of the dash board and saw where the shift connects to the stearing columum was cracked, trying to find the name of that piece[/quote:07f5ef51de]
Jan 11, 2009 at 2:32 AM
NETTECH
I still have never found the name of the piece but went to a junk yard and bought a steering colum and took the piece off of the colum, since I couldn;t find it anywhere but the dealer and they wanted a couple of hu8ndred for the part and couldn;t give me a name for it
Jan 11, 2009 at 2:49 AM
ZEUSWS6
  • 5 POSTS
Just curious. How much did you spend on the steering column at the junkyard?
Thanks for the reply,
Chris
[quote:e983ccfdbd="nettech"]I still have never found the name of the piece but went to a junk yard and bought a steering colum and took the piece off of the colum, since I couldn;t find it anywhere but the dealer and they wanted a couple of hu8ndred for the part and couldn;t give me a name for it[/quote:e983ccfdbd]
Jan 11, 2009 at 3:48 AM
NETTECH
$120
Jan 11, 2009 at 3:52 AM
ZEUSWS6
  • 5 POSTS
I got it all apart and the pot metal molded bracket piece it pretty much destroyed. It's broken in about 4 places and cracked in a few more... I've found I can shift just using the rods however. I've got some connections I'm going to check to see if they can rebuild the crappy cast part... we'll see...
Thanks again for the replies!
Chris
[quote:4242fbe48a="nettech"]$120[/quote:4242fbe48a]
Jan 11, 2009 at 3:55 AM
ZEUSWS6
  • 5 POSTS
I think I should invest in some toys so I don't need to use my transportation for fun...
Jan 11, 2009 at 5:23 AM
