1999 Chevy Suburban rotors
84,000 MILES • V8 • 4WD • AUTOMATIC
HAROSMA
I have been trying to remove the rotor of my car for almost 3 days. Can you please tell me what magic trick will allow this to be removed. It is absolutely crazy that so much time has been wasted and I still cannot remove. I have read up on this and found different answers but still no luck.
Mar 13, 2008 at 9:53 AM
THE FACTORY MAN
  • 50 POSTS
I assume you can't get the rotor off the hub? I am not sure when GM started doing this but on my 2005 Silverado 4X4 there is a single torx or allen head screw (can't remember which) that fastens the rotor to the hub. Check to see if you have that fastener and remove it.
Mar 20, 2008 at 6:48 AM
