1999 Chevy Suburban Replacing brakes?
1999 CHEVROLET SUBURBAN
180,000 MILES • V8 • 2WD • AUTOMATIC
GEMINI8859
Hi, I have a 1999 Chevy Suburban C1500 1/2ton with a V8 standard(not turbo diesel). I'm trying to replace the front brake pads, but I've run into a problem. I've noticed that I can't get the caliper to fit onto the rotor correctly after placing the new brake pads on. The hole where you insert the mounting bolts protrudes a bit and then I can't fit it onto the caliper mount, the new pads make it about a quarter inch too thick. Any suggestions?
Jun 16, 2010 at 4:20 PM
BMRFIXIT
  • 19,053 POSTS
Make sure that the caliper piston is set all the back in
Jun 16, 2010 at 11:43 PM
GEMINI8859
Yes, that is the first thing I tried. It was suggested that I try to get the sleeves to slide back in, so I'm trying that today.
Jun 19, 2010 at 11:25 AM
