1999 Chevy Suburban REAR A/C
REYESFIDENCIO
  • 1999 CHEVROLET SUBURBAN
Air Conditioning problem
1999 Chevy Suburban V8 Four Wheel Drive Automatic
My rear ac blower motor has power going to it. But
when I hook the plug back into the blower motor I
loose power. I have already tried the resistor and the relays in the rear area. What could be my problem. Also are there other relays in the front that would affect the rear a/c?
Tuesday, July 27th, 2010 AT 4:34 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Are you using a volt meter to check for voltage? If you are set meter on OHM scale check across motor terminals unpluged. Also check with OHM meter the ground wire Black wire to body for contiuity.
Let me know
Thanks for donate
Wednesday, July 28th, 2010 AT 2:17 PM
