1999 Chevy Suburban Heater A/C problem
DANIEL28
  • 1999 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 154,900 MILES
The air blowes out of the defrost vent. Neither hot or cold. The circulation and A/C buttons do not light up. I checked the fuse and its fine. Any ideas.
Wednesday, May 28th, 2008 AT 10:42 PM
RHALL77
  • 3,361 POSTS
Sounds like the AC controler went bad and is set to a default setting. You can try to disconnect it and see if it starts working again, but most likely you will have to replace it.
Thursday, May 29th, 2008 AT 7:36 AM
