1999 Chevy Suburban power steering
1999 CHEVROLET SUBURBAN
132,000 MILES • V8 • 2WD • AUTOMATIC
RB042
I turned the whell all the way to the left to bleed the front calipers and now the wheel is hard to turn. At first it was hard to turn the right to bleed the other side but now it is hard to turn in any direction. Can,t drive it.
May 10, 2008 at 3:02 PM
MASTERTECHTIM
  • 4,750 POSTS
does it have power steering fluid in it? when turning the wheel and its hard, does the power steering pump whine like its struggling? if it does not whine then the pump shaft probably broke and you need to replace the pump. i have seen it alot of this truck and was not caused by something that you did.
May 11, 2008 at 12:17 AM
RB042
You were absalutly right! It is the pump shaft that it broken. How do I remove this EVO sensor from the back of the pump? I am down to just that in order to replace the pump itself.
May 11, 2008 at 8:18 AM
MASTERTECHTIM
  • 4,750 POSTS
i dont remember. check for a internal snap ring.
May 11, 2008 at 9:02 AM
