1999 Chevy Suburban Loose roter
1999 CHEVROLET SUBURBAN
BIGKURTK
Shakes or Wobbles problem
1999 Chevy Suburban V8 Two Wheel Drive Automatic
I have a loose roter on the front driver side of my Suburban and it is casusing the front end to pull and shake. How can I titen it or fix it?
Sep 7, 2009 at 5:43 AM
DOCFIXIT
  • 18,828 POSTS
Pull tire , remove caliper , then center dust cover then cotter pin and nut. Remove outer bearing inspect the rotor and inner bearing. Most likely will need to replace both bearings.
Sep 7, 2009 at 6:10 AM
