1999 Chevy Suburban Leaking Oil/Water mixture
CLEWIS.IT
Engine Mechanical problem
1999 Chevy Suburban V8 Two Wheel Drive Automatic
I just fixed a coolant leak on this engine (broken quick connect). Now I find the engine is mixing oil and coolant, plus it is leaking "oil" from behind the crankshaft pulley. Do you have any recommendations on what the problem might be?
Jul 10, 2008 at 9:42 AM
  • 75,988 POSTS
Either you're leaking thru the headgasket or cracked head or block and intake manifold. Also the leak in front of the vibration damper is coming from the crankshaft front seal
Jul 10, 2008 at 9:46 AM
