1999 Chevy Suburban keeps running hot
1999 CHEVROLET SUBURBAN
DANNYBMACK
Engine Cooling problem
1999 Chevy Suburban Automatic 70000 miles
i changed the water pump, and thermostat....ac and heater does not work.
Oct 18, 2008 at 8:57 AM
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: ,Pressure test the Rad. cap,Clogged radiator,air lock in the cooling system ,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Oct 18, 2008 at 9:28 AM
