Ignition Firing Order
98,000 MILES • V8 • 4WD • AUTOMATIC
EPETRUS
I need the spark plug firing order for my suburban. It is a 7.4 engine.
Jun 6, 2008 at 3:45 PM
  • 75,988 POSTS
7.4/454CID
https://images.2carpros.com/forum/automotive_pictures/12900_fo_9.jpg
Jun 6, 2008 at 7:44 PM
WARREN TRACY
Thank you for the info on the fireing order on my 99 subruban. the check engine light came on and when I checked it it gave me a code of #6 cylinder missfire,
I cleard code and it ran for 20 or 30 mls, and it came on again, so I'm checking the wires and spark plug,
if that dosent do, ware do I go from there?
I am not working so I can only send $5.00 I Hope that will do, for now
Thanks in advance
Warren
Dec 4, 2019 at 12:57 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Next would be to inspect vacuum hoses for damaged or loose connections. Check throttle body and intake manifold for vacuum leaks. Also the PCV valve operation and vacuum lines. A compression check and leak down test on the cylinder will be needed if you still haven't found a fault.
BOBBY.EXUM
How do you correct the firing order for spark plug wires?
THIS IS MIKE
  • 686 POSTS
Chevy Surburban 1500
https://images.2carpros.com/forum/automotive_pictures/46392_firing_order_chevy_suburban_1.jpg
Firing order
350 TRANS AM
i need to know the firing order for a 1987 suburban with a 350....and also the order they go on the cap. thanks alot
  • 75,988 POSTS
Here you go, Sir
https://images.2carpros.com/forum/automotive_pictures/12900_fo1_4.jpg
