1999 Chevy Suburban heat causes surburban to die
1999 CHEVROLET SUBURBAN
118,000 MILES • V8 • 4WD • AUTOMATIC
CARTAK
When the temp is 80 or higher outside, while driving engine dies. While in process of dying if I push the gas too hard it just dies out but if I barely push gas I can make it about 2 minutes before it dies. After about 10 minutes of waiting I can restart it and drive about 30 minutes before it dies again. I replaced the ignition control module and ignition coil but that didn't help...any ideas what is causing this engine or fuel problem? Thanks!
Jul 13, 2010 at 6:24 AM
HMAC300
  • 48,601 POSTS
check your fuel pressure when it happens if you can. that particular year had a problem with the harness going to the fuel pump. alot o f the replackement fuel pumps come with a ppieceof harness that is about a foot long that must be replaced along with the fuel pump. it would be a good idea to change the fuel filter as well...if there are no service engine codes it could also be the crank sensor or cam sensor...... they sometimes will not set a code but go bad....
Jul 14, 2010 at 12:26 PM
