1999 Chevy Suburban grinding noise while coasting
166,000 MILES • V8 • 4WD • AUTOMATIC
TERRYHILL3092
99 chevy suburban 4wd...grinding/growling noise only when coasting and turning right. Just replaced wheel bearing on driver's front did not help. Mechanic wants us to drive it until it gets worse as they can't figure it out. Is it transfer case or CV joint or other? thanks!
Nov 22, 2009 at 1:47 PM
  • 110,248 POSTS
It could be a couple things. It could be the output shaft bearing on the transfer case or the input bearing of the differential.
Nov 29, 2009 at 1:43 PM
