1999 Chevy Suburban Gas Gauge Issues
130,000 MILES • V8 • 4WD • AUTOMATIC
SPENCEDOG
99 suburban gas gauge didnt work when i bought it.The fuel pump went out a little over a year ago so i replaced it.Then the gas gauge worked.Well now it doesnt work again!!! any ideas?
Sep 14, 2009 at 3:10 AM
HMAC300
  • 48,601 POSTS
GM had a problem with those tanks and it was found that the harness was bad and cause fuel pumps to go out. It can be a bad connection or just a bad sending unit. If you hae power to the sending unit( low voltage blinking light) then the problem is the sending unit itself.
Oct 6, 2009 at 11:16 AM
