1999 Chevy Suburban Fuel Problems
BIG O BURBAN
Engine Performance problem
1999 Chevy Suburban V8 Two Wheel Drive Automatic
On my 1999 Chevy Suburban I have replaced the fuel pump twice this time I replaced the fuel pump and the fuel filter you hear the fuel pump come on and I remove the fuel filter and gas pours out when you turn the key on so I replace fuel filter as well but the truck will not start. If you spary starting fuild into the breather it will crank but once starting fuild burns up engine dies what could be the problem??
Nov 1, 2010 at 3:24 PM
  • 75,988 POSTS
Check the fuel pressure if its within specs and check if the injectors are pulsing
Nov 1, 2010 at 5:19 PM
TIMOSOJIOVANI
I also have 99 Suburban that ran great right up until last Saturday. It cranks over, has a spark, the fuel pump relay works, but the fuel pump isn't running?
It seems strange that it would run right up until we shut it off and than not run since? I suspect it's the fuel pump but hate to start replacing parts unless I'm sure of what is wrong?
Nov 4, 2010 at 12:58 PM
TILICKE21
[quote:adfa079683="TimosoJiovani"]I also have 99 Suburban that ran great right up until last Saturday. It cranks over, has a spark, the fuel pump relay works, but the fuel pump isn't running?
It seems strange that it would run right up until we shut it off and than not run since? I suspect it's the fuel pump but hate to start replacing parts unless I'm sure of what is wrong?[/quote:adfa079683]
I have a 1997 that did the same thing. We put 5 pumps in it before someone said quit with the pumps already & check the harness. Didn't know what I was doing but rolled under the truck drivers side just in front of the rear tire. Just on top of the gas tank there was a wire harness with 1 wire hanging by a thread. I twisted it back up, taped it & haven't had that trouble again since then...hope you will be as lucky !!!
Nov 5, 2010 at 4:21 AM
BIG O BURBAN
Fuel pump replaced Crank postion sensor replaced Ingtion coil replaced fuel filter plugs and wires? still will not start truck cranks but will not start fuel pressure good. HELP??????????????
Nov 8, 2010 at 10:23 AM
