1999 Chevy Suburban fluid turned brown
1999 CHEVROLET SUBURBAN
238,000 MILES • V8 • 4WD • AUTOMATIC
CAMPNHUNT
what causes the brake fluid to turn brown.I sucked all the fluid out of the master cylinder and replaced it with new fluid about two weeks ago it seems like the front brake are heating up sometimes in city driving I can smell them any ideas
Jun 21, 2008 at 12:28 PM
THE FACTORY MAN
  • 50 POSTS
Any signs of fluid contaminated by petroleum products, such as swollen master cylinder lid rubber gasket? You probably need to do a complete flush of the brake fluid and start from there. Start with the contamination question and we can go from there. If the fluid is contaminated with a petroleum product, motor oil, trans fluid, etc, you are facing a big expense. Has someone else recently serviced the brakes or added fluid?
Jun 23, 2008 at 1:23 PM
CAMPNHUNT
[quote:620152dcb7="The Factory Man"]Any signs of fluid contaminated by petroleum products, such as swollen master cylinder lid rubber gasket? You probably need to do a complete flush of the brake fluid and start from there. Start with the contamination question and we can go from there. If the fluid is contaminated with a petroleum product, motor oil, trans fluid, etc, you are facing a big expense. Has someone else recently serviced the brakes or added fluid?[/quote:620152dcb7] no one has serviced my brakes last spring I had the brake system bled and refilled and the the fluid turned brown again I do tow a camper with the truck but it has its own brakes front and rear brakes are in good shape what should I do?
Jun 25, 2008 at 12:35 PM
THE FACTORY MAN
  • 50 POSTS
If there is no sign of swollen rubber components I think I would do a complete brake fluid flush and refill with fresh GM DOT 3 brake fluid which is clear in color and then re-evaluate any problem which may still exist.
Jun 25, 2008 at 12:44 PM
