1999 Chevy Suburban Evap sensor getting code P0452
125,000 MILES • V8 • 2WD • AUTOMATIC
PAULZ
I bought the sensor but no one knows where to install it or how...help please.
Paul
May 3, 2008 at 2:33 PM
ROB2008
  • 258 POSTS
Evaporative Emission Control System Pressure Sensor Low Input indicates a low voltage problem in the Fuel Tank Pressure Sensor (FTPS). What the fuel FTP sensor does is convert fuel tank absolute pressure into electrical signals and inputs the signal to the ECM/PCM, (Computer).
First thing to do is make sure the gas cap is good and tightened properly. Then check the vacuum lines and wiring at the FTPS (Location-Fuel Tank) to be sure they are good, clean and tight.
Barring a wiring problem it can be a bad FTPS or PCM.
May 3, 2008 at 2:59 PM
