1999 Chevy Suburban Electrical Problems
ROB EDDINS
  • 1999 CHEVROLET SUBURBAN
  • V8
  • 68,600 MILES
While driving, I will loose all electrical power causing everything to go dead including the engine, radio, door locks, windows, etc. What could be the causes and how do I test to verify?
Thursday, January 31st, 2008 AT 9:59 PM
BILLYBOBASAN
  • 12 POSTS
Hello Rob, Make sure your battery cables are clean & tight, also your ground cable to engine & your engine to body ground. After that I would suspect the ignition switch on the steering column. If you have the column with plastic cover top & bottom, remove the bottom cover (3 torx or philips screws) & with engine running wiggle the wires going to switch under the key. You may also duplicate problem by wriggling the ign key with engine running.
Good luck Sir,
Billybob
Friday, February 1st, 2008 AT 7:25 AM
