'99 was a split year; my door handles are horizontal and lift upwards.
I recently replaced the driver's door handle assembly and reinstalled all connectors and panel items. All functions on the driver's door master switch assembly are working properly. (note: to get the engine to start after completing the door repairs, I had to remove the ground wire from the battery and short it to the still-connected positive cable to reprogram the ecm.)
However, the individual electric window switches on the RF, RR, and LR doors do not operate at all. The windows do operate off the master switch panel on the driver's door, but not off the individual door switches.
I replaced the OEM #12077863 electric window circuit breaker, but that did not solve the problem.
I removed the circuit breaker and used a multimeter to check for voltage where the breaker mounts on the panel, but got only random voltages in the range of .003-.005v.
Which makes it seem that there is no 12v voltage reaching the panel socket for the circuit breaker; but that doesn't explain why the window switches on the driver's door master switch panel are all working properly.
Where do I go from here????
Oct 28, 2009 at 8:13 AM
