1999 Chevy Suburban cooling fan
1999 CHEVROLET SUBURBAN
75,000 MILES • V8 • 4WD • AUTOMATIC
GAW
please describe how the clutch fan is removed from the water pump, set up is not like classic 350 engines.
Mar 19, 2008 at 10:56 AM
MIKE H R
  • 3,094 POSTS
With the clutch fan are held on by nuts. With pressure on belt so engine and fan wont turn you have to loosen up each one at a time, turning the engine by hand a little to get at the next one, sometimes you will find little space between radiator and fan. When all nuts are off the remove the cluch fan watch out for the raditor.
Mar 19, 2008 at 11:59 AM
