1999 Chevy Suburban Brake lights and shifter
1999 CHEVROLET SUBURBAN
180,000 MILES • V8 • 4WD • AUTOMATIC
WHEELER4512
my suburban was having issues with the brake lights. well i checked the light then the fuses and came to the conclusion that is was the brake light switch. i replaced the brake light switch and the brake lights still didnt work then when i started it i could not shift out of park. i know the bulbs are good because i have tested them in different sockets. any ideas whats wrong.
Jun 12, 2010 at 8:00 PM
HMAC300
  • 48,601 POSTS
check the ground going to the sockets as well as where they connect to the truck. Alot of times that iis what the problem is . IF it doesn't come out of park the avits switch may not be releasing. If you have a console , ther eshould be a silver button to push under it to release it from park....
Jun 16, 2010 at 5:02 PM
