1999 Chevy Suburban blower motor
90,000 MILES • V8 • 2WD • AUTOMATIC
JZIENTEK
I have a 1999 Suburban and my blower motor is stuck on high. It will not turn off unless I turn the car off. I have already changed the blower motor resistor and the blower motor relay. Any ideas as to what is causing the blower to only work on high? Blower motor or AC control switch?
Thanks,
Jason
Jan 5, 2010 at 10:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
a/c switch would be most likely culprit here. if blower motor fails it will either blow lighter than normal, make a noise or not blow at all.
Jan 5, 2010 at 2:15 PM
