1999 Chevy Suburban antifreeze in oil
200,000 MILES • V8 • 4WD • AUTOMATIC
FSP
engine overheated - radiator was replaced
antifreeze is in the oil.
compression is between 170-190 in all cylinders
where do i go from here?
Apr 29, 2008 at 9:03 AM
MERLIN2021
  • 17,250 POSTS
This would indicate a cracked water jacket, or the water pump itself may have leaked into the engine. Anti freeze destroys bearings very quickly...
Apr 29, 2008 at 9:08 AM
BMRFIXIT
  • 19,053 POSTS
check head gasket
coolant mix with oil indication of head gasket failure
Apr 29, 2008 at 9:09 AM
