1999 Chevy Suburban AC Leak in line to the rear unit.
1999 CHEVROLET SUBURBAN
SCHO2STE
Air Conditioning problem
1999 Chevy Suburban V8 Four Wheel Drive Automatic
I have a leak in the AC lines that go to the rear cooling unit. I was quoted by a chevy dealership of a $3000-$4000 bill to get it fixed. That is insane. There has to be a way to fix it at a much cheaper rate. It is a small hole in an aluminum line. There must be a fix out there rather than the $300-$400 cap that they had to offer that does not let the refrigerant get back to the rear unti. Please help as this SUV hauls kids in town and the AC is important for my sanity
May 17, 2010 at 9:56 AM
HMAC300
  • 48,601 POSTS
unfortunately the only fix is to replace the lines. You ca'nt weld those lines due to a poisonous gas being produced during welding. If you go to GM parts direct.com you might be able to find the lines and replace them yourself then have your system evacuated and recharged by a pro. That would be your cheapest option. look under browse catalong and enter your info.
May 18, 2010 at 1:36 PM
MRXX
check out www.streetrodguys.com they have rear a/c block kits and a/c line repair kits for just about any vehicle
Apr 19, 2011 at 6:57 PM
