1999 Chevy Suburban 4x4 out
140,000 MILES • V8 • 4WD • AUTOMATIC
GSMITTLES
What is the possible cause of the 4 wheel drive not engaging? It's an electronicly controlled system. When I push the All Wheel drive button, the light comes on but the 4x4 doesn't engage. If I press 4x4 HI I get an idiot light that says Service 4 Wheel Drive System. Of course, 4x4 Low won't engage either. Any ideas on what the repair cost might be?
Nov 25, 2008 at 4:00 AM
PEAR69
  • 1,482 POSTS
It is most likely the actuator motor on the transfer case or the axles. However, it could be as simple as a switch or a loose ground.
Actuator motors are somewhat easy to replace but the part costs around $300 plus labor.
Nov 25, 2008 at 4:54 AM
