1999 Chevy Suburban
BOGIESBBQ
Electrical problem
1999 Chevy Suburban V8 Automatic
my Suburban is running rich at idle and has a miss , I hook up my scanner to it and it will not communicate with the truck ,It tells me to make sure its turned on or check fuses (witch are all good) or check grounds witch I checked ,and they all show to be hooked up . If I could get the problem with the scanner I should be able to get codes to fix the miss and rich problem.
Aug 20, 2009 at 4:52 AM
DR LOOT
  • 2,311 POSTS
tell me what kind of scanner you are using, the reason I ask because they are not all compatible
Aug 20, 2009 at 3:49 PM
BOGIESBBQ
mac TASK MASTER
Aug 21, 2009 at 4:20 AM
DR LOOT
  • 2,311 POSTS
Most likely you will have to take your vehicle to your local parts store and see if their scanner will download your codes they will do that for free, and then let me know what the codes are.
Aug 21, 2009 at 4:24 AM
